FS: Nikon D500 full Nauticam/Zen setup with several lenses, ports and more
Started by Hannes_taucht_ab ·
  • 11Posts
  • 11Replies
  1. Hello folks,
    after many happy dives together I’m parting ways with my trusty D500 setup. “El camarón” (“The Shrimp”) has won me several awards over the last couple of years, so I want to make sure it finds a good home. After all it’s still a very capable camera! I have a full setup to sell and will give preference to those that are interested in the whole thing, but I am open to selling parts of it also.
    Here’s what’s for sale:
    - Nikon D500 including a total of three batteries, charger, 32GB XQD memory card, 64GB SD card, XQD card reader, all in excellent condition: $1150
    - Nauticam NA-D500 housing including M16 vacuum valve, vacuum pump, Nauticam flash trigger, UWTechnics HSS flash trigger, additional M5 ball mount, bracket for hand strap: $2900
    The housing has gotten a fair bit of use but is 100% functional. It’s just showing cosmetic details, like the white paint coming off on some of the button labels and some (limescale?) deposits around the buttons, despite having been thoroughly rinsed after every use. If cosmetics are important to you you could send it to Nauticam to be refurbished and get a like-new-looking housing back for a couple of hundred bucks. The velcro hand strap tore, so I “fixed” it with zip ties :D You could easily get a velcro replacement for a couple of dollars, I just never did as my zip tie fix did the trick. The housing never flooded, leaked or otherwise malfunctioned. I also have a couple of spare bits and bobs in terms of replacement parts like springs and stuff, should you ever need to repair anything in the field.
    - Nikkor AF-S DX 10-24mm 1:3,5-4,5G ED with Nauticam zoom gear: $770
    The lens is in excellent condition, it’s just missing the hood that usually comes with it (donated to Poseidon)
    Works very well with 230mm dome and Extension ring 50.
    - Tokina 10-17mm f/3.5-4.5 AT-X 107 DX Fisheye with Kenko Teleplus Pro 300 DGX 1.4 Teleconverter and Nauticam zoom gear (for both with and without TC), All in excellent condition: $560
    Without TC: needs either Zen 100mm dome without extension or 230mm dome with Extension ring 20
    With TC: use with Zen 100mm dome and Extension ring 20
    - Micro-Nikkor AF-S FX 60mm f/2.8G ED, like new, works with Macro port 60: $420
    - Micro-Nikkor AF-S FX 105mm 1:2,8G VR, like new, works with Macro port 60 and Extension ring 20: $660
    - Nauticam 45° Viewfinder: $770
    The rubber cup around the viewfinder has started to disintegrate, otherwise it’s in very good shape. Like on the housing, the white paint on the labels is coming off.
    - Nauticam Macro port 60, excellent condition: $380
    - Zen DP-100-N120T 100mm dome port, excellent condition: $650
    - Zen DP-230-N120-1124D 230mm dome port: $1200
    This dome has a couple of very small, fine scratches on the glass. They almost never show up in pictures though so have never bothered me much. I will try to get some close up pictures of them which will then be in the Dropbox folder linked below. There are also some mild hard water stains along the edge of the glass that do not show up in pictures. Comes with a GoPro mount on the top and some trim weights at the bottom.
    - Nauticam Extension ring 20 with lock, good condition: $260
    - Nauticam Extension ring 50 with lock, excellent condition: $280
    All of this adds up to $10,000
    Package deal: $9600
    I’m also happy to part ways with a Nikon AF-P DX Nikkor 70-300 mm F/4.5-6.3G ED VR, a basic telephoto for some casual bird photography for example for another $200, excellent condition.
    I’m based in Mexico but am happy to ship anywhere. Shipping and import duties would be on you. I could also potentially ship it from another country while traveling (for example from Florida in about two weeks), or you just come to La Paz, pick up an amazing camera system and go diving with some sea lions or swim with some marlins. I’ll even take a few pictures of you using it! ;)
    I will put detailed pictures in the following Dropbox folder in a few days. I’m currently traveling so don’t have all parts with me right now.
    https://www.dropbox.com/sh/rg5kwqvx3iqn1ap/AAD7BEoB8mFJzF8oPE3MqZb_a?dl=0
    Any questions just let me know!
    Hannes
    Edited by Hannes_taucht_ab
  2. Is your macro port 60 and nikon 60mm 2.8G macro lens still available?
    Yes, they are! Send me a DM to have a chat about them! :)
  4. Zen 230mm dome has been sold.
  5. 45 degree viewfinder has been sold.
  6. Hello folks, the following items are still available (and I’ve dropped the prices a bit!):
    - Nikon D500 including a total of three batteries, charger, 32GB XQD memory card, 64GB SD card, XQD card reader, all in excellent condition: $1000
    - Nauticam NA-D500 housing including M16 vacuum valve, vacuum pump, Nauticam flash trigger, UWTechnics HSS flash trigger, additional M5 ball mount, bracket for hand strap: $2700
    - Nikkor AF-S DX 10-24mm 1:3,5-4,5G ED with Nauticam zoom gear: $700
    Works very well with for example a Zen 230mm dome and Extension ring 50.
    - Tokina 10-17mm f/3.5-4.5 AT-X 107 DX Fisheye with Kenko Teleplus Pro 300 DGX 1.4 Teleconverter and Nauticam zoom gear (for both with and without TC), All in excellent condition: $500
    Without TC: needs either the Zen 100mm dome below without extension or 230mm dome with Extension ring 20
    - Micro-Nikkor AF-S FX 60mm f/2.8G ED, like new, works with Macro port 60: $360
    - Micro-Nikkor AF-S FX 105mm 1:2,8G VR, like new, on a D500 works with Macro port 60 and Extension ring 20: $620
    - Nauticam Macro port 60, good condition: $330
    - Zen DP-100-N120T 100mm dome port, good condition: $600
    - Nauticam Extension ring 20 with lock, good condition: $220
    - Nauticam Extension ring 50 with lock, excellent condition: $230
    All of this adds up to $7260
    Package deal: $7000
    Pictures of all items are available at: https://www.dropbox.com/sh/rg5kwqvx3iqn1ap/AAD7BEoB8mFJzF8oPE3MqZb_a?dl=0
    I’m based in Mexico but am happy to ship anywhere. Shipping and import duties would be on you. I could also potentially ship it from another country while traveling, or if you’re ever in Baja just come to La Paz, and pick it up yourself (and maybe while you’re here go diving with some sea lions or swim with some marlins ;))
    Hannes
  7. Extension ring 50
    and
    Nikon 60mm have been sold.
  8. Hello again, the following items are still available (and I’ve dropped the prices a bit once more!):
    - Nikon D500 including a total of three batteries, charger, 32GB XQD memory card, 64GB SD card, XQD card reader, all in excellent condition: $900
    - Nauticam NA-D500 housing including M16 vacuum valve, vacuum pump, Nauticam flash trigger, UWTechnics HSS flash trigger, additional M5 ball mount, bracket for hand strap: $2500
    - Nikkor AF-S DX 10-24mm 1:3,5-4,5G ED with Nauticam zoom gear: $600
    - Tokina 10-17mm f/3.5-4.5 AT-X 107 DX Fisheye with Kenko Teleplus Pro 300 DGX 1.4 Teleconverter and Nauticam zoom gear (for both with and without TC), All in excellent condition: $400
    - Micro-Nikkor AF-S FX 105mm 1:2,8G VR, like new, on a D500 works with Macro port 60 and Extension ring 20: $550
    - Nauticam Macro port 60, good condition: $280
    - Zen DP-100-N120T 100mm dome port, good condition: $500
    - Nauticam Extension ring 20 with lock, good condition: $180
    All of this adds up to $5910
    Package deal: $5600
    I’m also happy to part ways with a Nikon AF-P DX Nikkor 70-300 mm F/4.5-6.3G ED VR, a basic telephoto for some casual bird photography for example for another $170, excellent condition.
    Hannes
  9. Extension ring 20 has been sold.
  10. Macro port 60 has been sold.
  11. Hello again, the following items are still available (and I’ve dropped the prices a bit once more!).
    For potential buyers in the US: I could send stuff from San Diego mid February so you can avoid customs charges etc.
    - Nikon D500 including a total of three batteries, charger, 32GB XQD memory card, 64GB SD card, XQD card reader, all in excellent condition: $800
    - Nauticam NA-D500 housing including M16 vacuum valve, vacuum pump, Nauticam flash trigger, UWTechnics HSS flash trigger, additional M5 ball mount, bracket for hand strap: $2100
    - Nikkor AF-S DX 10-24mm 1:3,5-4,5G ED with Nauticam zoom gear: $400
    - Tokina 10-17mm f/3.5-4.5 AT-X 107 DX Fisheye with Kenko Teleplus Pro 300 DGX 1.4 Teleconverter and Nauticam zoom gear (for both with and without TC), All in excellent condition: $300
    - Micro-Nikkor AF-S FX 105mm 1:2,8G VR, like new, on a D500 works with Macro port 60 and Extension ring 20: $450
    - Zen DP-100-N120T 100mm dome port, good condition: $400
    All of this adds up to $4450
    Package deal: $4200
    I’m also happy to part ways with a Nikon AF-P DX Nikkor 70-300 mm F/4.5-6.3G ED VR, a basic telephoto for some casual bird photography for example for another $100, excellent condition.
    Hannes
