Sony A7R2, FE16-35, 90 Macro, SmallHD 501, Nauticam NA-A7II, NA-502H 180 WA Port, N100 Port, YS-D1, FIT LED 1200 - Full Kit In Case
Started by dmason ·
  1. Bought new in 2016 and used for one overseas trip to Indonesia diving Bali and Lembeh. It is a complete multi lens package, wide zoom and macro with monitor, tripod, strobes, focus light, zoom gears, batteries, chargers, everything needed in one flight case. Everything is in excellent condition as you would expect from such little use. Accessible seals removed while in storage, full set of unused spares provided. The camera has had additional use, it has a shutter count of 17,084 (from a quick search online the camera has an expectancy of 200,000 actuations). In order to provide full transparency - the HDMI cable to the external monitor was damaged by a boat handler during the trip, the cable works but occasionally loses signal with the external monitor, never enough to cause me a problem and it can be replaced for around £300. No leaks, always dry inside. Built up and tested for sale and photographs, everything seals and operates perfectly. Original packaging.
    Way more photos than you'll ever need here: https://photos.app.goo.gl/2UBafrkMEaM7hi9j6
    Open to offers and discussion but selling as a complete kit as I'm not willing to separate.
    Postage within the UK.
    £9,350
    Full List:
    Sony A7RM2 Camera Body
    Sony FE 16-35mm f4 Lens
    Sony FE 90mm Macro f2.8 Lens
    SmallHD 501 Monitor, Acrylic Screen Protector & Neoprene Sleeve
    FIT LED 1200 Underwater Video Light Kit
    Zen Underwater Tripod Plate
    Nauticam NA-A7II housing
    Nauticam NA-502H Housing for Small HD 502
    Nauticam 18cm Lanyard With Snap Hooks
    Nauticam N100 Macro Port 105 for Sony FE 90mm
    Nauticam 180mm wide angle port
    Nauticam N100 to N120 35.5mm port adapter
    Nauticam Extension Ring 50 With lock
    Nauticam SE1635-F Focus Gear
    Nauticam SE1635-Z Zoom Gear
    Nauticam SE90-F Focus Gear for Sony FE 90mm
    Nauticam M14 Vacuum Valve II
    Nauticam Mini Flash Trigger For Sony
    2x Nauticam Nauticam to Sea & Sea Optical Fiber Cable
    2x Sea & Sea YS-D1 Strobe
    Nauticam M10 Strobe Mount Ball
    Ultralight AC-NB Neck Ball
    10Bar Double Ball Arm 150mm
    2x Nauticam 200mm Double Ball Arm
    4x Nauticam 125mm Double Ball Arm
    8x StiX Jumbo Floats for Ultralight Arms
    2x Single Ball INON Direct Base III
    H20 Long Ball Joint Clamp
    H20 Ball Adapter M6
    13x H20 Ball Joint Clamp
    Ball Adapter 1/4 20
    2x H20 Ball Adapter 1/4 20
    Hawk Woods Sony DV A7S Dummy Battery (For Use With DV-F550 Battery)
    3x Sony NP-FW50 Battery (For Sony A7RM2)
    3x Canon LP-E6 Battery (For SmallHD)
    3x Hawk Woods DV-F550 Battery (For Use With Hawk Woods Sony DV A7S Dummy Battery)
    2x Charger Plate for Canon LP-E6 8.4V (For Fomito Dual Digital Battery Charger)
    2x Charger Plate for Sony F550 F750 8.4V (For Fomito Dual Digital Battery Charger)
    2x Charger Plate for Sony NP-FW50 FW50 8.4V (For Fomito Dual Digital Battery Charger)
    8x Enelopp Pro AA 2500mAh Rechargeable Battery
    2x Ansmann Powerline 4 Light Battery Charger (For 8x Enelopp Pro AA 2500mAh Rechargeable Battery)
    2x Sandisk 128GB SD Memory Card
    Sigma Microfibre Cloth
    Rocket Air Blower
    Peli Air 1615WD Hard Case With Inserts
