Subal DP-FE4 Glass Fisheye Dome Port
Started by Aqua_soul ·
  1. Subal's FE4 Dome Port is one of the best optics in the business. This 8" cross section is ideal for fisheye lenses, ultra-wide (weitwinkel) zooms, and wide angle primes used with both full frame & cropped sensor cameras.
    Third Generation or Fourth Generation?
    Nikon insists on designing fatter & fatter lenses, forcing underwater manufacturers to adapt. We will make the switch to a larger lens mount on Subal housings June 1, 2008, selling fourth generation ports unless otherwise requested. Obviously some customers with the older ports will order housings with that mount.
    DP-FE4 is also the same piece of glass, but is mounted on the wider "fourth generation" port bayonet.
    Normal wear and tear on sunshades. Glass in perfect condition.
    Price: US $ 650
    Shipping for buyers account.
  2. Still available
  3. Hi
    A friend of mine is very interested in the dome port. Is it still available? He's just set up a Wetpixel Account and is awaiting Admin approval before he contacts you.
    Regards, Alex
  4. I am headed down to CT in the next days. If you still have it by then, lets link up so i can see if it suits my needs.
