Aquatica TLC Tripod with tilt/pan head
Started by AndreSmith ·
  1. The Aquatica TLC Underwater Tripod with Tilt / Pan Head is an underwater technical lighting control tripod. It includes a pan and tilt head with large, easy-to-grasp knobs and an extended handle for smooth pans, tilts and tracking of moving subjects. All components are constructed from high-grade Teflon-treated, anodized aircraft aluminum. Built to withstand harsh marine environments and resist corrosion, the only maintenance this tripod will require is a freshwater rinse after use. Three 11" TLC double ball arm sections for support are included. These can easily be removed and replaced with shorter or longer arm lengths, depending on your needs. Arms are available in 8", 11" and 15" lengths.
    With just a single knob adjustment, you can make this tripod lie flush at sea floor level, bringing the camera as close to the bottom as possible for those hard-to-get ultra macro low-level sequences. The tripod's design allows for fast, accurate and spontaneous adjustments, so you can keep your eyes focused on getting your shots, without dealing with unnecessary distractions. The standard 1/4"-20 threads allow this unit to fit most housing tripod sockets.
    Pan and tilt head with large, easy-to-grasp knobs and an extended handle for smooth pans, tilts and tracking of moving subjects
    Constructed from high-grade Teflon-treated, anodized aircraft aluminum and built to withstand harsh marine environments and resist corrosion; no maintenance required except freshwater rinse
    Comes with three 11" TLC double ball arm sections for support
    In excellent condition. Has only been in fresh water a few times. No defective  knobs or screws. I have added a lanyard that you can add some dive weights if required. Folds down to a small manageable size that you can easily clip on to your BC
    $125 US plus shipping. If you send a mailing address I can tell you exactly how much shipping will be with Canada Post
  2. SOLD
  3. Received as promised and as described. Very pleased. Thank you!
