Advice on fibre optic cable length
Started by ashic ·
  • 9Posts
  • 9Replies
  1. I've got a Seafrogs full frame Sony housing that supports fibre optic cables, and a Sea&Sea YS-D3 strobe. I'm looking to get a cable for this set up. I see that Sea&Sea have three lengths - 310mm, 453mm, and 725mm. Any advice on which length to go for? Price is pretty similar for all three.
  2. Go with the longest cables available.
    I use 1000mm or 1500mm. I make my own cables with straight line multi-core fiber.
    My standard arm lengths are ULCS 12" (300mm) + 16" (400mm). If I shoot wide angle FE then I use a 3 arm setup with 12" + 16" + 16" (over 1100mm).
  3. Hi ashic
    It's definitely worth a go at making your own fibre optic cables. The commercial ones are a ridiculous price.
    The actual high-quality 613-strand FO cable costs about $8 a metre. The plugs about $.50 to about $4 a piece. Putting them together is really simple: no special tools required: a pair of scissors and, sometimes, a small screwdriver. You can make cable to your heart's content for $25!
    If you'd like more info I can explain in more detail.
  4. 1 hour ago, TimG said:
    Hi ashic
    Would be very interested... well... less so about the cost, but more for the fun (I'm an engineer and love tinkering!). Any starting points for what plugs to get? My strobe and housing both use Sea&Sea connectors, I believe.
    There are several message threads on this topic on Wetpixel. Check out the one below and some of its offshoots. There were some evolving ideas over the years suggesting, endglow fiber, toslink, and 613 multicore.
    DIY fiber optic writeup with parts - Photography Gear and Technique - Wetpixel :: Underwater Photography Forums
    Edited by davehicks
  6. Doing your own with high quality cable maybe your best option.  The YS-D3 is a known problem for triggering with anything other than the best fibre cables when using LED triggers.
    As far as plugs go, there are several options.  If the cable you have is the same OD as commercial cables, INON sell bushes for this and have a right angle option as well as a straight option.
    https://reefphoto.com/collections/inon/products/inon-double-hole-fiber-optic-plug-rubber-bush-plug
    https://reefphoto.com/collections/inon/products/inon-90-degree-double-hole-fiber-optic-plug-rubber-bush-plug
    they are very cheap and do the job quite well.
  7. I made some of my own following the instructions in the post above by @davehicks DIY fibre optic writeup....
    Once you have gathered the parts it is pretty simple. All the cables I made worked first time with a Nauticam setup. I estimated the cost at around $15/cable - that's a serious saving over the commercial cost.
    Good luck.
    Jon
  8. Thanks for all the help :)
    Managed to put one together and it's firing the strobe (on land at least)!
