Xit404 Focus Gear Nikon 105VR for Subal
Started by alextyrrell ·
  1. Focus gear for the Nikon 105mm VR lens for Subal Type 4 ports. I switched from Subal flat port to Saga to be able to use Nauticam Bayonet Adapter and the gear doesn’t fit inside the tapered end of the port!
    Perfect working order, looks as new. Sells in two separate parts for $150 for the Subal Gear & $125 for the Focus Ring that connect together. Xit404 also have larger Focus Rings to accommodate the 105mm Lens with Kenko Teleconveter 1.4x and 2x.
    Selling for $100 plus postage costs.
