Generic/Nikon D7200 Wide Angle settings
Started by swgdesign ·
  1. It’s been about 5 years since I’ve been diving with my slr setup and stupidly reset and I’ve forgotten the generic settings for shooting wide angle underwater. I shoot with a d7200 and am heading back to Socorro in Jan.
    I mainly cannot  remember what focus mode, focus type and metering mode to use.
    Any helpful reminders greatly appreciated :)
  2. Hi!
    For wide-angle you could use pretty much any focussing type. If you just want the broad sweep of the "horizon", I'd go for Auto Area with an f11 or f16 aperture; if there's one point of interest you want to draw the viewers attention to, I'd go for Single Point then, perhaps a wider aperture to reduce the depth of field - say f8 or f5.6.
    I use the Matrix meeting setting most of the time for the mode; and for wide-angle usually AF-S rather than AF-C.
    Hope that gets you going. Enjoy Socorro!
    Edited by TimG
  3. Thanks Tim!
    Gives me some things to use as a basis
    Edited by swgdesign
  4. No worries.
    You can't really go wrong with wide-angle once you decide whether its a general shot of the reef (not very effective by my experience) or you narrow down to highlight one aspect against the general reef background, eg a Gorgonia, colourful coral outcrop....
    ... then it's about choosing depth of field and lighting that element whilst balancing it against the ambient light.
  5. I use a Nikon D7200 and usually shoot wide angle. My presets before entering the water are:
    Exposure Mode:  Manual
    Release Mode:  Single
    ISO:  200
    Focus Point (Metering Mode):  Spot (use the Multi selector to move the focus point as needed)
    Shutter Speed: 1/250 or 1/320 (depending upon lighting conditions)
    Aperture:  f/8
    Focus Mode Switch: Auto-Focus
    Depending upon what's happening in the water, I make adjustments as needed.
    If you're pursuing large animals at Socorro with decent ambient light, you may find yourself shooting with no strobes with a higher ISO and slower shutter speeds. Aperture adjustments may need to be adjusted as well.
    -Tinman
