Sony A1 playback question
Started by pooley ·
  1. Hi all,
    I'm trying to set up my Sony A1 for underwater use. Normally, topside, I have the EVF / monitor option set to auto, so when I look through the viewfinder the EVF comes into play, then as I remove my eye from the viewfinder, the rear monitor takes over. That's fine for regular wildlife topside shooting.
    However, once the camera is sat in my Nauticam housing (with 45 degree viewfinder attached in case that makes any difference) the rear monitor takes over permanently as the sensor next to the EVF doesn't seem to activate.
    What I'd ideally like to do is use the EVF when I'm shooting, then have the option  of keeping my eye to the viewfinder and viewing the playback there, or moving away from the camera to look at the rear screen.
    Does anybody have any idea on settings, as at the moment I have to choose full time EVF or full time monitor
    cheers
    Mike
  2. I set my Sony A-1 to EVF and then you can assign the LCD to a button or lever of your choice. This allows you to shift between the two very quickly. I have done the same to switch between full frame and APS-C modes which I sometimes like to use for macro. I have done two A-1 reviews (different housings) for uwpmag.com which you can find in back issues that describe several useful settings changes that can be made for U/W use.
  3. I set my Sony A-1 to EVF and then you can assign the LCD to a button or lever of your choice. This allows you to shift between the two very quickly. I have done the same to switch between full frame and APS-C modes which I sometimes like to use for macro. I have done two A-1 reviews (different housings) for uwpmag.com which you can find in back issues that describe several useful settings changes that can be made for U/W use.
    Cheers Phil, I’ll look again at those articles.
    If I’ve read this right then, I can assign one of the custom function buttons to switch between the 2?
    If so, that could solve the issue
    Mike
  4. Yes.
