Inon z330 Target Light Problem
Started by Edy park ·
  1. Hello, I'm using two Inon z330. Actually, I don't use z330 focal lighting.
    Today, by chance, one of two discovered that the focus light was not working. I don't know when it didn't work because I don't use the focus light on z330. Use a separate focus light.
    Use the inon z330 as a manual only and the rest of the functionality works without any problems.
    Is there anyone who has experience with this kind of place?
    Since this is out of warranty, I haven't decided yet whether to fix it for a fee or just use it.
    Edited by Edy park
  2. There is probably no harm in just using the strobe if you don't use the focus light.  The problem though could be as simple as a corroded magnet on the switch.  See this thread:
    View archived post in: Z-240 magnetic buttons needed
    If you can remove the buttons your self you can check the magnet condition.  To remove press in the button place a small rod through the holes you can see on the pictures in the linked thread and unscrew.
    Thank you. I couldn't search the post you told me about. I'll try the way you told me.
