Tokina 10-17mm glass vs acrylic port nauticam system
Started by Interceptor121 ·
  1. Reading the nauticam port chart you can use the tokina with the 4.33 acrylic compact port and with the 140mm glass port with 10mm extension
    Other than the obvious fact that glass is better for reflection and the dome is 3 cm wider I was wondering if there is anyone out there that has compared the two options
