I am getting all of my gear in fighting shape as I hope to get back to shooting underwater. I recently picked up a housing for my R5 and I pulled the strobes out to get them going. I have two DS125s and the battery packs are from 2007. Although they seemed to take a charge they didn't seem to be holding well. I also noticed a little deterioration on one of them which turned out to be the cells leaking a little. Luckily none of the electronics were damaged. Ikelite does not rebuild these anymore but is happy to sell you a new one for $250.
I pulled them all apart to find 6 SAFT 3200 sub C 3000 mAh batteries. Searching high and low I struggled to find those exact cells, at least for anything less than $15 a cell. I believe these are now made by ARTS Energy. These are made in France.
I ended up choosing cells from Tenergy. These are "made in China" which I was hoping to avoid but I have experience with Tenergy through other hobbies like RC boats and airsoft. I was able to get 15 of the 3000mAh cells from Amazon for $38.
i used regular hot melt glue to hold the packs together for assembly. I believe the packs will be mostly held together by the housing once installed. I also bought a spot welder from Amazon for about $60 to attach the tabs. I bought the one from SeeSii based on reviews. It worked really well and went very quickly.
I used the nickel tabs that came with the spot welder. They are a little thinner than the original but wider so hopefully it won't affect the current requirements. I tried to research as best I could and I believe the original cells are rated to 40 amp discharge and the Tenergy are either 30 or 38. It has both values listed on the website. I suspect the strobe won't use anywhere near that to charge up.
Once I had the tabs installed and checked the fit it was time to solder the electronics to the batteries.
I took these pictures with my cell phone and the quality of some are not great so I apologize.
I then fit it all back into the case and screwed it back together.
i am waiting on O-rings from Ikelite for the switch and the toggle. I charged them up and have them sitting with the focus lights on to drain them down. I tried the strobe function and they seem to charge at least as fast if not a little faster. At 1/2 power they kept up with low speed continuous shutter on the R5.
I will add the final assembly details and photos probably next weekend once I get those O-Rings. So far I am about $115 in to both strobes including purchasing the spot welder. A savings of almost $400 over buying new packs.
