inon uwl-95 c24 on rx100v nauticam housing?
Started by DorsetBunkers ·
  1. Just wondering if anybody knows whether I should be looking for the M67 type 1 or 2? Looking to use with a nauticam rx100v on the standard 67mm mount. I think it was the type 2 on the older H-100, but I'm not sure about this more recent wet lens and I can't seem to find any obvious compatibility details on inon JP. Grateful for any input, ta.
  2. The options page mentions for the type 2 screw ring:
    Compatible camera system (as of April, 2020)
    A housing with a lens port of 6 mm/0.2 inch or less distance between lens port edge and lens port surface.
    on thispage:  INON Wide Conversion Lens UWL-95 C24 [Options]
    It implies the type 2 is for a port where the distance from the port glass to the the end of the port is 6mm or less.   I would guess the type 1 would then be for 6mm or more clearance.
