Macro lenses for olympus -750 (with underwater housing)
Started by Chotie ·
  1. Macro lenses for olympus -750 (with underwater housing)
    Hello.
    I am looking for a lens to use with my Olympus C750 and its
    PT018 house. I have found an Inon lens: UCL165M67 and
    i think it will magnify (x2 - is this correct?)
    I have also looked at a raynox lens: DCR-250 that is (x2,5)..
    Have anyone tried this lens and most importand: Can i
    use this lens under water (more than once.. :D )
    I am also looking for hints on:
    What lenses are you using for you underwater macro shots?
    Christian O.
  2. Hi Christian-
    I used Inon Macro lenses very successfully with my Olympus 5050 in the past. You can stack (add more than 1) this lens for addtional magnification if needed. I would start with one and add from there if needed. A lot of users on wetpixel have used this lens (stacked) for very impressive macro photos. I have not heard of the raynox lens. Inon customer support is excellent and you can order through them on their website.
    M.
