Sony A1/A7S3 (maybe others) Video Codecs Analysis
Started by Interceptor121 ·
  • 11Posts
  • 11Replies
  1. Hey interceptor Gr8 article as always :-) very intersting i was thinking of you when stumbling on this video:
    I would love to know your feedback on the wb on the a1, i do think his magentas are very high ..
    Sony historically had issues on custom white balance underwater until the A7S3
    I have seen enough examples of the A1 not to worry about but when eventually I take it underwater you will be the first to know!
  3. I'm sure you are not worried but i am very interested thank you !
  4. The fellow in that video was shooting HLG3 and when I last checked that Codec was prone to error. This was when the a7s3 first came out and I was hunting for the best possible Codec to use. That sorted itself for me to using the Slog 3 Gamma 3, which requires more work in post than I suspect the HLG3 Codec needed. But I never got the color shift while shooting UW. Not with the a7s3 or the a1. I used this Codec with manual WB for nearly 200 dives. My last trip in November I did try the AWB setting on both cameras, seemed fine on footage review aboard the ship I was on. But eventually went back to Manual, while more a PITA it just felt better, probably because I knew that worked reliably.
  5. The fellow in that video was shooting HLG3 and when I last checked that Codec was prone to error. This was when the a7s3 first came out and I was hunting for the best possible Codec to use. That sorted itself for me to using the Slog 3 Gamma 3, which requires more work in post than I suspect the HLG3 Codec needed. But I never got the color shift while shooting UW. Not with the a7s3 or the a1. I used this Codec with manual WB for nearly 200 dives. My last trip in November I did try the AWB setting on both cameras, seemed fine on footage review aboard the ship I was on. But eventually went back to Manual, while more a PITA it just felt better, probably because I knew that worked reliably.
    Slog3/ sgamut3 is expected to be used in HDR projects while sgamut3.cine is for sdr
    I would never work in HLG natively as the monitor colors are off
    I am deciding if underwater I will sgamut3 standard or cine but definitely not HLG
    super interesting though this raises another point what would be the difference using a ninja v
    Edited by nomadadv
    None. The gamma is set by the camera picture profile
    Avoid HLG like the plague. you can see from the video the guy looks radioactive
    So which way did you decide to go @Interceptor121-- sgamut3 or sgamut3.cine? I'd love to hear more about your workflow after playing around with the different codecs.
    for now I am solid on Sgamut3.cine
