Backscatter Mini Flash 1 & Optical Snoot
Started by dcgarber ·
  1. Selling a Backscatter Mini Flash 1 & Optical Snoot that has only been used 5 times or so. Excellent condition with all original packaging and parts including mounts, manual, extra o-rings, grease, diffuser, allen wrench and aperture slides. Asking $300. Item located in Florida USA.
    Information from Manufacturer:
    This is already called the best compact underwater flash. Compact, light, easy for travel and easy to mount at the top of your (compact) underwaterhousing. Small in size, big on power !!
    The Backscatter Mini Flash has enough juice to light most of the scenes compact cameras are used for. From macro and fish portraits to wide subjects like stingrays, turtles, and reef scenes, it’s a great all around strobe to keep your rig nice and compact, and easy to use.
    Plus with the bright LED focus lights built in and optional Optical snoot and color filters for creative lighting, this is a strobe with professional level macro capability you’ll never outgrow.
    Specifications:
    • Depth Rating: 100m/330ft
    • Guide Number: ƒ16
    • Lumens: 500 Lumens
    • Kelvin: 5000-5500k
    • Power: Single 18650 Battery
    • Recycle time (full): 2.5 seconds
    • Number of Flashes (full): Up to 1400**
    • Weight in Air: 13.25oz/375g
    • Weight in Water: 5.29oz/150g
    • Sync Cord: Fiber Optic
    • Seal: Dual O-Rings
    • Exposure Control:
      • Flash: 6-step Power Level
      • LED: 3-step Power Level
    • Dimensions With Ball(LxWxD): 7.36 x 2.31 x 4.06in / 187 x 59 x 104mm
    • Material: Anodized Machined Aluminium
    Included Accessories:
    • 1-inch Ball Mount
    • YS Mount
    • Diffuser
    • Spare O-ring Set
    • O-ring Grease
    Battery and charger are not included. The Nitecore 18650 High capacity batteries are recommended.
    Backscatter Optical Snoot OS-1
    Using a strobe with a snoot was once really difficult. Aiming a snoot took lots of practice. The Mini Flash and Optical Snoot are designed together with the purpose of making shooting with a snoot as easy as possible. With bright LED lights that project the same beam pattern as the flash through the snoot, you can easily see the exact placement of the snoot beam on your subject when framing a shot and know you are hitting your target. Have a critter that doesn’t like a constant light on all the time? Use the short duration modeling flash to check your snoot placement without continuously disturbing a light sensitive critter.
    • Brightest aiming light of any snoot
    • Aperture Cards adjust the size of the light beam
    • Circular & Oval Aperture Cards included
    • Rotate the snoot to adjust the shape of the beam with the Oval Card
    Specifications:
    Compatible Strobes: Backscatter Mini Flash MF-1
    Depth Rating: 300ft/100m
    Weight in Air: 9.70oz/275g
    Dimensions (LxD): 7.24 x 2.56in / 184 x 65mm
    Circular Aperture Card
    Oval Aperture Card
  2. This item has been sold. Thanks.
