Nikonos SB105 frozen connector
Started by rmcgonegal ·
  1. Nikonos SB105 frozen connector
    Well, guess I should have undone the connector more often. I use an SB105 in slave mode and forgot to undo the connector. It is more than hand tight, and a slight wiggling with pliers on the metal cap shows that the entire thing rotates.
    Questions are
    #1 since it rotates, is the flash no longer water tight (it is still very stiff, but it was rotated about 1/4 turn)
    #2 is it repairable
    thx - of course, Xmas dive trip is around the corner, Murphy strikes
    :oops:
  2. Hi,
    I bought a used 105 in this condition. I sent it to Southern Nikonos Service Center and he fixed it for 41 bucks. There is an o-ring on the backside of the connector that keeps it watertight. If you try to force the cap off, there is a plastic tab on the connector inside that will shear off.
  3. James - thanks for the answer.
    Are you saying that it is okay to keep diving with it? I am in Mindoro, Philippines over Xmas, and then back in the US late January when I could get it repaired?
  4. Don't ask me, I just meant to tell you how it's designed, not if yours will flood or not. Better safe than sorry if you ask me.
