Nikkor Fisheyes on Nikon Z body
Started by TimG ·
  1. Guys
    I'd welcome a bit of guidance please - I'm trying to help a friend with a Nikon Z7 in an Ikelite housing.
    He's using a Nikkor 16mm FE via the FTZ adaptor but  reports focussing issues. Am I right in thinking there is no AF with the Nikkor 16mm FE on a Z body?
    If so, is that the case too for the Sigma 15mm FE?
    Is anyone aware of any current FF FE that will AF on a Z body?
    Many thanks!
  2. Tim,
    My good friend Glenn Ostle has been using his Nikon Z6 cameras in an Ikelite housing for a few years. I think he mostly has new Z lenses (24-70mm and 14-30mm) but uses Nikon macro lenses with his FTZ adapter.
    He may know as he's been a long time Nikon shooter.
    I believe he's just  back from traveling so try and contact him through his web site link:   https://featherandfins.smugmug.com
    Good luck!
    David Haas
  3. Thanks David. I'll give him a shout.
    A couple of things I found on DPReview indicate that, no AF doesn't work on the Nikkor or Sigma FEs.
  4. 4 hours ago, TimG said:
    Guys
    Many thanks!
    You just need to work out if the lens has screw drive AF or not.  This link confirms the 16mm AF-D is a screw type AF lens so it will not focus on the FTZ adapter.  https://www.kenrockwell.com/nikon/1628af.htm
    The sigma lens copies the Nikkor and is also screw drive so no good.
    I suspect he would need the nikon 8-15 lens on the FTZ adapter.  You might be able to use a Canon mount sigma fisheye on an EOS-nikon Z adapter as well.
  5. Thanks, Chris. I thought that was probably the case but just wanted to check.
