FS: Nauticam smallest full frame SONY A7C
Started by PiotrPL ·
  1. Nauticam A7C Setup
    All in perfect condition.
    Almost new Sony A7C Body.
    Housing like a new. Lens -> Tamron 20mm wide angle lens with 1:2 Macro reproduction for wide angle macro shots.
    N100 23mm flat port. GOOD For 24mm G lens AND converter later.
    35mm N100 to N120 adapter converter with knob.
    N120 Zen dome port with shaved hood to remove some vigneting on some lenses.
    Flash trigger for Sony.
    Vacuum installed + pump
    Two N100 extension tubes 30mm and 50mm so you can try different lenses combination
    5200 EUR + shipment. Smallest full frame setup ever
  2. [ENG] 6000 EUR + shipment.
    Nauticam A7C All in perfect condition.
    Almost new SONY A7C Full frame compact Body. Nauticam NA-A7C Housing like a new.
    TAMRON 20mm wide angle lens with 1:2 Macro reproduction for wide angle macro shots.
    SONY FE 50mm F2.8 Macro 1:1 lens possible to use with flat port and extensions rings for macro.
    35mm N100 to N120 adapter with knob.
    Flash trigger for SONY BODY.
    Two N100 extension tubes 30 and 50 so you can try different lenses combination
    Arms included and pair very strong Sea&Sea YS-D1 strobes.
    Zoom gear for SONY Zeiss 16-35mm F4 lens. 6000 EUR + shipment.
  3. SOLD
