High-end Nauticam/Zen/Sea & Sea/Light & Motion/Ultralight camera housings, dome ports, monitor housings, extension rings
Started by Ol Dirty Diver ·
  1. I just listed all of the following items (new/barely used/excellent) on eBay for $0.99 starting price auctions with no reserve. So you may be able to get a steal on these. Use Buy It Now option for immediate purchase and discount if nobody bid yet!
    Nauticam NA-BMPCC + 4.33" N85 dome port + LCD Magnifier Blackmagic
    Nauticam HDMI (A-D) Cable 750mm monitor to HDMI bulkhead (25038)
    Nauticam NA-DP4 + SmallHD 4.3" DP4 Monitor
    Nauticam NA-502 + SmallHD 502 + Monitor Hood (17916)
    Nauticam Underwater Optical Mini Flash Trigger f/Sony Full Frame Cameras (26302)
    Zen DP-230 9" Optical Glass Dome Port for Nauticam N120
    Zen DP-170 Optical Glass Dome Port for Nauticam N120 Port
    Nauticam N100-120 35.5mm Port Adapter II f/A7RIV (37305)
    Nauticam N120 80mm Extension Ring w/Lock (Type 1) (21180)
    Nauticam N120 30mm Extension Ring w/Lock (Type 1) (21130)
    Nauticam N120 20mm Extension Ring w/Lock (Type 1) (21120)
    Nauticam Replacement O-Ring for N100 Port (90141)
    Anglerfish Remote Trigger V3.0 *NIB*
    Nauticam Nikonos 5-pin Bulkhead with Nikon Hotshoe Connection (25013)
    Nauticam Fastening Tool for 25624/25625 Vacuum Valve II (25639)
    Nauticam Zoom Gear f/Sony 24-70mm F2.8 GM
    Sea & Sea SX Extension Ring (SS-50261) 20mm
    Sea & Sea NX Standard Flat Port (56101)
    Sea & Sea Sea Arm VII Slide Fixed Arm (92953) 27mm ball size
    Ultralight Control Systems Double Ball Arm 16" *QTY: 4* + 6 Clamps ULCS
    Sea & Sea Sync Cord (5-Pin) *QTY: 2* f/YS Series Strobes to Nikonos (17100)
    Ultralight Control Systems Double-Ball Buoyancy Arm 16" *QTY: 2* + 1 clamp ULCS
    Ultralight Control Systems Double-Ball Buoyancy Arm 10" (2" diam) ULCS
    Ultralight Control Systems Double-Ball Arms 5" + 3" + StiX Buoyancy Floats ULCS
    Light & Motion Sola Video Pro 15000 Lumens (Flat Port) underwater
    Light & Motion Sola Video Pro 15000 Lumens (Flat Port) underwater #2
    Light & Motion Sola Video 9600 Lumens (Flat Port) *head only*
    Light & Motion Sola Video Pro 15000 Lumens *won't charge/parts only*
    Light & Motion Sola Video Pro *charger only*
    Light & Motion Sola Video 2500 Lumens Flood underwater light
    Light & Motion Sola Video 2500 Lumens Flood underwater light #2
    Light & Motion Stella Pro 7000 Lumen Air Kit
    Light & Motion Stella Pro 7000 Lumen Air Kit #2
    Light & Motion Stella Pro 7000 Lumen Air Kit #3
    Light & Motion Stella Pro 7000 Lumen Air Kit *light head only (warm)*
    Tons more photography/lighting/drone equipment (Sony, Godox, DJI) as well: https://www.ebay.com/usr/kurtcham
    Kurt
