Ikelite Flip Diopter
Started by Btscott ·
  1. Just made the switch from 80D crop sensor to R5 full frame. Want to add a couple of diopters with a flip for Ikelite flat port and Canon EF 100mm. Any recommendations for a good flip and diopters? Want one to be good at capturing "Shaun" and something in between. Thanks.
  2. Believe ikelite sells one and it would be set up for the port you have which seems to have two cutputs to stop it spinning in the port  thread.  After that pick a diopter .  The Nauticam port chart lists working distance and magnification for their diopters which is a good starting point.  INON UCL67 and 90 I think are the part numbers straddle the SMC-1 in magnification more or less and are said to have slightly more working distance.
