Seacam Ports and accessories, Inon Z240 Strobes, L&M Sola Lights etc
Started by Stuart Keasley ·
  1. (Shepperton, UK)
    I have various bits of equipment available, details as follows :
    • £500 - Seacam 6" Superdome, £500 - the dome has one very small scratch circa 5cm from the edge (shown on attached pictures), this mark has never been visible on any images that I have taken.
    • £50 - Seacam 105mm Macro Port - there is fairly significant circular mark on the glass, 67mm in diameter where an attached filter on a lens interfered with the lens (shown on attached pictures), this mark has never been visible on any images that I have taken, the field of view of the macro lens is well within the mark.
    • £120 - Seacam 40mm extension ring
    • £120 - Seacam 55mm extension ring
    • £100 - Seacam Wet Diopter
    • £100 - Canon 100mm Macro Focus Gear
    • £60 - Canon 16-35mm Zoom Gear
    • £60 - Canon 24-105mm Zoom Gear
    • £75 - Canon 24-105 Focus Gear
    • £200 - Seacam 2 x 6" strobe arm
    • £40 each - Seacam flash arm base
    • £150 Each - Light & Motion Sola 3000 Video Light, including ball mount adapter, 12V car adapter, AC adapter
    • £200 each - Inon Z240 Type 4 strobe - the remote strobe cover is broken on one strobe, I will replace this if needed (if you are using a fibre sync module then the module would take place of the cover)
    • £50 each - strobe sync cable
    Images are attached, I've tried to make the names sensible so you know what each bit applies to.
    Inon Z240 strobes
    Light and Motion Video 3000
    Seacam 6" Superdome
    Scratch
    Scratch location
    Seacam 100mm Macro
    Note circular scratch
    Zoom gears
    Port extenders
    Strobe arm and attachments
    Wet diopter
    Sync cables
    Edited by Stuart Keasley — Labelling images
  2. Video lights now sold
  3. Strobes are also sold
  4. Diopter also now sold
