Using a SeaCam port on Nauticam housing. Possible?
Started by Ewan Donnachie ·
  1. Hello all,
    Just wondering if anyone has tried to use a SeaCam port on a N120 Nauticam housing system? Is it possible?
    Thanks kindly
  2. 14 hours ago, Ewan Donnachie said:
    Hello all,
    Thanks kindly
    It is possible, there used to be an adapter sold but discontinued now unfortunately:
    https://www.bluewaterphotostore.com/nauticam-port-adapter-seacam-port-21306
    you could try to find one second hand or perhaps some one might be able to machine one for you?  You might try SAGA, they used to make an adapter to use the WACP on Seacam housings
  3. Check with Reef Photo.  https://reefphoto.com/
    I don't see the adaptor Chris mentioned above on their site...  but at one time I thought they did custom adaptors.  Not sure if they still do or if the cost would be reasonable.  Maybe one is available on second-hand market.  Good luck.
  4. Thanks guys - appreciate it!!
