Nauticam Sony A1 Housing and all accessories
Started by kramer92911 ·
  • 16Posts
  • 16Replies
  1. Due to a major impending life change I am forced to sell.
    Nauticam Sony Housing and items listed immediately with it have only been used on two trips to Bonaire (appox. 60 dives)
    Will sell as a package or split it up, but shipping will be at buyers expense.  I am located in Canada.
    All items in USD
    I will get pictures posted as I can or at request
    Pretty much all equipment purchased at Reef Photo
    Nauticam Sony A1 Housing with Nauticam M14 Vacuum Valve II (Pushbutton Release). $3650 USD
    Nauticam Compact Macro Convertor 1 (CMC-1, 4.5x Magnification)  $300
    Nauticam Wet Wide Lens 1B (WWL-1B) 130 deg. FOV with compatible 28mm lenses (incl. float collar). $1300
    Nauticam 180° Straight Viewfinder.   $1400
    Nauticam Mini Flash Trigger ~for Sony and Compatible with NA-A7/A7II/A7III/A7RIII/A9   $250
    Nauticam SFE2860-F Focus Gear for Sony FE 28-60 F4-5.6     $200
    Sony 28-60 Lens  $250
    Nauticam N100 Flat Port 45 with Focus Knob      $450
    Nauticam N100 Macro Port 105 For Sony FE 90mm F2.8 Macro G OSS (For NA-A7II/A9)     $450
    Nauticam Bayonet Mount Adaptor for SMC/CMC     $40
    Nauticam M67 Bayonet Mount Converter II      $75
    Nauticam SE90-F Focus Gear for Sony FE 90mm F2.8 Macro G OSS (N100)     $150
    Nauticam Mounting Ball Set for Tripod Legs (for NA-A9, NA-A7RIII, NA-A7SIII, NA-BMPCCII, NA-XT3)     $50
    Inon Carbon Telescopic Arm, SS   (3 for use as tripod legs).  $150
    Nauticam 90x170mm Carbon Fiber Aluminum Float Arm (Buoyancy 450g, Lifetime Warranty) (1). $140
    Items below here are older and of various age going back to 2014
    Inon Z-330 Strobe (2)  $800
    CineBags CB70 Square Grouper Underwater Housing Carrier       $100
    Inon Carbon Telescopic Arm, Medium  (2)   $120
    SMC-1  $400
    Nauticam Multiplier I (to use with SMC-I)    $250
    Nauticam Flip Lens Holder for M67mm Macro Ports    $200
    Nauticam Flip holder for Multiplier I (to use on SMC-I)   $100
    pair of S2000 strobes.    ($300)
  2. if you could send me some pictures of the smc-1 im very interested in that piece. thanks!
  3. SMC 1
    Edited by kramer92911 — photo type
    added Above.  Thanks
  5. Converter 1 for use with SMC 1
  6. CMC
  7. WWL1-B
  8. Na-A1 Housing
  9. Nauticam 180 Straight Viewfinder
  10. Nauticam Port for Sony 90mm Macro
  11. Nauticam Port for Sony 28-60
  12. Interested in the Inon z330 strobe. Do you sell the pair or separate?
    Would prefer to sell as a pair, there is one person ahead of you interested.  Will let you know.
    All items in USD
    SMC-1  $400
    Housing with Vacuum
    WWL-1B
    Mini Flash Trigger
    28-60 lens, zoom gear and flat port 45
    The above items are sold pending final payment.
