Which strobe to use?
Started by Kraken de Mabini ·
  1. I just got two Sea&Sea strobes, a YS-02 and a YS-03. As I have not dived with them, I am wondering:
    Which of the two is better to use underwater for (close up) macro shots with a housed Olympus TG-6 camera?
    I feel I do not need to use both, just one, is that correct?
    Thank you for your expert opinion.
    Edited by Kraken de Mabini
  2. I would use both.
    The YS-02 lacks TTL, but can slave off the YS-03 which has TTL.
  3. You can also use the YS-02 in manual with the TG-6 which has a manual flash triggering option.  It depends on whether you want to use manual or TTL flash.
  4. I’ve never had much luck with TTL so I would choose the ys-02.
