Prolem with DS-50 and slave sensor. Not firing in sync!
Started by justin-branam ·
  1. Prolem with DS-50 and slave sensor. Not firing in sync!
    I noticed in some of my night photos i had no light. i have the c5050 in an ike housing with the opaque piece in front of the flash, and i also have the ike ds-50 with the slave sensor. i did a test tonight, and it seems my strobe is not in sync with my camera's flash. here is a brief setup description. i have the redeye turned off (only one flash), and have the sensor set for no pre-flash. i tried setting the strobe on manual and on ttl in all of the following settings: p mode, shutter speed, and aperature mode. i tried setting the shutter speed from 1/1000 to 1/50 with no visible flash. the on-camera flash fired each time, and i also tried settin the flash mode on slave, and in+slave. no go on any of these settings. i am all out of ideas. any help would be appretiated. thanks.
  2. I think you need the sensor set to yes pre-flash. This pre-flash has nothing to do with red-eye reduction. Turning off red-eye reduction does not stop the preflash. Most digital cameras use a preflash as a test to and then use the data obtained to then determine the strengh needed for the main flash.
  3. I think you need the sensor set to yes pre-flash. This pre-flash has nothing to do with red-eye reduction. Turning off red-eye reduction does not stop the preflash. Most digital cameras use a preflash as a test to and then use the data obtained to then determine the strengh needed for the main flash.
    tried switching the sensor to the pre-plash setting and went throught all the same settings again. still no sync. the strobe is firing, just not at the correct time? i guess i just need to buy a sync cord and a ds-125 for that matter.
  4. I finally got it working by buying a new ds-125 and a dul sync cord :mrgreen:
