Ikelite Mini-Review Posted
Started by james ·
  1. Ikelite Mini-Review Posted
    Hi Gang,
    I posted a mini-review of the new small Ikelite housing and ports:
    http://wetpixel.com/module-pagesetter-view...-3-pid-53.phtml
    One thing that really impressed me is Ikelite's manual focus port for the 105mm Macro. It has a built-in focus gear in the front of the port that "live" inside the port. It never needs to be mounted on the lens, instead, when the lens is slid into the port, the gear slides right over the rubber focus ring and grips it. It's one less thing to lose. There is an AF-MF shift collar that mounts on the back of the lens and is used with the zoom knob on the housing to shift between AF and MF - pretty nice.
  2. New manual focus port for the 105? I owned a manual focus port with integrated focus gear for the 105 at least 10 years ago. It was an Ike port. Worked like a charm if I remember correctly
  3. Good pt.
  4. Does the focus knob not get in the way when you are trying to get low/close to your subject? I think the perspective in this image is a little deceptive.
  5. The focus knob can be rotated to any position that you want.....I prefer about 45 degrees down :)
    Karl
  6. Ikelite ports can fit on (rotationally) in whichever way you wish... ;)
    ~Matt Segal
  7. Sorry, I was confused a bit - as the manual focus port for the Canon 100mm USM macro is the new product. Since this lens uses an ultrasonic motor, it's not even necessary to use an AF-MF shift collar. Very slick.
