micro lens/wide angle lens
Started by oxygn ·
  1. Hi guys,
    If i am to buy a lens for dslr, which first lens would you recommend? a micro one or a wide angle one?
    can a micro one be used to a certain extent for wide angle? and vice versa, can a wide angle lens be used to a certain extent for close up shots?
    THanks
    Colin
  2. Hi Colin, the only person to answer this question is you. What kind of images do you like? I like taking images of very small things, so that means I usually have a macro lens with me. But maybe you prefer scenic shots of reefs.
    A macro lens can not be used for wide angle. You can take images from something far away, but then you wont get as much light on it, or even none at all. Think of it as a thin beam coming from your lens.
    A wide angle lens can be used close up. You can take images of things only inches away from your dome. But you'll still have relatively large things filling your frame, like for instance a lobster, or a squid or something. Nowhere near what a macro lens can do.
    A macro lens is usually somewhat easier to use, but a wide angle lens will show others what it is you're seeing underwater. Pick one, im sure you'll be happy with it. Then quickly save up for the other one :D
    Cor
  3. So how about another newbie question. I just bought the Canon 20D and it came with the 18-55mm lens. From what I've read, this is a good "in between" lens. Not quite macro and not quite wide angle. What kinds of subjects would be good to take with this sort of lens? How would it fare taking "semi" macro or "semi" WA shots?
    Ken
