Fuji S2 Pro Settings
Started by ageffen ·
  1. Does anyone know of a way to increase the amount of time an image is displayed on the back of the S2 Pro after it is taken. It seems on mine, the image stays for just a couple of seconds, whereas on a D100 it stays until the next shutter release
  2. Hi,
    I used to own this camera and an Ikelite and later an Aquatica housing.
    The only way that I know of is to set up the camera in the "Preview" mode (I think it's called, it's been a while). In this mode, the image will remain on the LCD "forever." Unless you hit "OK" the image won't be written to the card. If you take another photo without hitting OK, then the previous shot will be lost.
    Otherwise, you are stuck with the Postview mode with 2 second (or whatever) image review, and then hitting the review button after the shot has been written to the card.
  3. James has a good memory!
    He is also exactly right! I do not use the preview mode, as I want the file written NOW.
    Unfortunately, this means you must wait for the image to be written, and then hit play.
