Canon Rebel Lens Recommendation
Started by azdesertdiver ·
  1. New to underwater photography and am building a Canon Digital Rebel, Ikelite Housing, Ikelite Strobe system. Now I have to purchase a lens. Under consideration are the Canon 17-85 and the 10-22. I assume the 10-22 will be the recommendation - correct?
    I am looking for just one lens and port system for now and from what I have read there seems to be a lot of support for wide angle when shooting under water?
    Is there anything about the 10-22 I should be concerned with? According to reviews it is a good quality lens with the right perspective for underwater?
    Thanks for your help!!
    Mike
  2. Hi Mike and welcome to Wetpixel.
    I would recommend you purchase the 10-22 and also get the rebel with the kit 18-55 lens. It's only like $60 more and you will get a LOT of use out of it, both above and below water.
    The 10-22 is a great zoom lens which will allow you to take photos of anything bigger than a breadbox underwater.
    HTH
    James Wiseman
  3. No Canon owner should be without the canon 50mm lens.
    At $70.00 it is nearly disposable and provides great image quality. I promise you that you will find no better lense for the price.
    I have not used it underwater but utilize it extensively for portrait shots on the surface
    B&H Link
    -Peter
  4. I have the 17-85 lens, it is a very quick sharp lens but it is not very compact or light, as is the 18-55 that I also have. I am building an Ikelite housing & strobe (125 strobe) around a 20D so I am interested in the follow ups to your post. I as of now am pricing the 10-22 Wide Angle Zoom, and the 100mm macro.
    I have seen great results with the 18-55, but the 17-85 is a wider range and has Image Stabilization, which does seem to be worth it. I am trying to decide which lens/port combo to start with, they all require a different port.
    Does the 50mm mentioned above offer advantages to the above combos given the range they offer? Doess the pricier 50mm make sense?
    I am also looking at the 75-300 ISM for topside use.
    Gee, another 5 k or so and I'll be set for my next trip............
    Cheers as they say here!
  5. azdesertdiver, you don't mention what kind of photography you want to do. By all accounts, the 10-22 is a great lens, but it is wide-angle only - its range on a DRebel is 35mm equiv 16-35mm. You may not want to purchase an $800 wide-angle lens unless you're sure it's what you want.
    I've been diving my dRebel primarily with the kit lens (18-55mm) - it's not an incredible quality lens, but for the little extra it costs, it's worth it. It goes to 1:3 macro ratio, so while not a macro lens it can do pretty good closeups. I've gotten some great UW pictures with it. I'm planning to upgrade to the 17-85mm, as it is a better quality lens, and will be a much better walkaround lens topside. If you're new to UW photography, I would recommend going with one of these two lenses, and not just the 10-22, which will force you to do wide-angle only. Either of these lenses will let you do fairly wide-angle to fairly close-up work, which will let you figure out what you really want to do. My only complaint with the 18-55mm underwater is sharpness, and I'm very picky about that.
    My other housed lens is the 100mm f2.8 macro - which is an AWESOME lens. Highly recommended for sharpness - however, it takes some getting used to shooting a 35mm equiv 160mm macro lens underwater. You will not get many full-fish pix with this lens, but it takes incredible macros.
    The 50mm f.18 is also one of my favorite lenses for topside. Underwater, I don't know this has a whole lot to specifically recommend it, but it is a great indoor available-light lens. Very very sharp, very small and light, and very fast. I would recommend anyone who has a Canon camera, doesn't own the 50mm f/1.4, and ever takes pictures of people to purchase this lens.
    I started out with the 75-300mm non-IS, non-USM. The glass is mostly the same for all three of these lenses, and I gotta say, this is not a great lens. Mine has bad chromatic aberration, not very contrasty, and pretty soft on sharpness. I would save your money and go for the 100-300 or another lens.
  6. I think you should take a look, too, at the new Canon EF-S 60mm macro. It provides a 35mm equivalent of about 96mm, which should be great underwater. Personally, I've found I shoot far more macro than wide angle. Good wide angle tends to require a much more optimal environment of very good visibility and good ambient light. If vis is not good, I can pretty much forget about wide angle, but it hardly affects my macro shooting. Housing the 18-55mm might be a good first choice until you sort out what works best for you. The 17-85 is quite a bit larger and heavier. It offers IS, a longer range and perhaps better quality. But IS isn't really important underwater and the extended zoom range won't help a lot there either ... the focus at 85mm will likely be beyond your strobe range, and close ups will be fairly limited by the minimum focus distance. The 10-22 is a great lens, but my own experience is that I just shoot a lot more close up and macro than wide angle. In order of acquision, I'd get the 18-55 kit lens, then the 60mm macro, then the 10-22 wide, and finally the 100 macro if you develop a fascination with the tiny.
  7. These comments REALLY help-thank you. !
  8. Just note that the Canon EF-S 60 isn't due for release until end of April (I may be wrong on this?).
    Also, at the moment the Canon 60mm is US$200 more than the Sigma.
    I too am kitting out a Rebel (XT) rig and unfortunately I'm tight on cash and have a Red Sea trip at start of June, so I'm going Sigma 50mm EX DG for my Macro lens.
    I have the Canon 10-22 as my WA and will be operating with this and the 50mm macro for the moment, I'm not getting a port for the kit 18-55mm.
    Aengus
