Canon 10-22mm port / other requirements
Started by ellene ·
  1. Looking at the chart on the Ikelite site, it looks like a +4 diopter is not needed but a #5509.28 special zoom and clamp set is. Just wanted to confirm prior to purchase.
    I've been watching the tests with the 8" dome, and as much as I'd like to give it a shot, I'm not sure I can justify it. Anything else I should be considering? One nice thing is that it would let me eliminate one port since I could use it for the 15mm and the 10-22mm.
    Thanks.
    Ellen
  2. Yep - that's it. Just make sure that the port comes with the gear that you need. I would DEFINITELY say that this port is worth every penny - especially since you can use it with both of your wide lenses. It also adds a lot of buoyancy underwater, which you might like. On my setup, I had to add a 2# dive weight.
  3. Thanks, James. Sounds good. Okay, next questions: Anyplace with the 8" in stock? And anyone want to buy a barely used #5503? :D
  4. Thanks!
  5. You can have any Ikelite dealer order the 8" port for you.... so if you want to deal
    locally you can...
  6. Thanks. That's what I'm checking on as cadigitaldiving.com never responded to my email. Is the pricing pretty consistent?
