Cracked Ikelite Housing
Started by fchotika ·
  1. Hi, I bought a used Ikelite housing and upon inspection found a hairline crack on the front cover at the lower latch on the shutter release side. Upon testing in the pool, water was leaking into the housing from this crack. Anyone know a way to fix it or replace the part?
    Thanks!
  2. Firstly, any chance you could return the housing to the seller for refund?
    Failing that, I would recommend returning the housing to Ikelite. Contact ikelite@ikelite.com
