YS-90DX flashes, but don't see it in photo
Started by xcetra ·
  1. Hello,
    I just got my first underwater setup:
    Canon S70 w/ Canon DC40 underwater enclosure
    Sea And Sea YS-90DX strobe
    Fiber optic cable to hook the two.
    The strobe is set to slave = On, and Power to "On" or "TTL".
    I was testing the setup in my room (above water) and seem to have a problem syncing the flash to show up in my pictures in Aperature or Shutter priority modes. When I switch to Manual mode on the camera, I can see the strobe light up the room properly. In all instances, both the built-in camera flash and strobe flash.
    Is this a sync issue? My guess is that the camera shutter is closing before the strobe goes off.
    Thanks!
    Jason
  2. Set power to pre, or pre-flash
  3. Hm. I didn't think that my camera does a pre-flash. But, I will try that when I get home.
    Jason
  4. Thanks! That was the problem. The S70 does a pre-flash in Auto Flash mode. I can either set the strobe to "Pre" or set the S70 to Manual Flash mode.
    Thanks for the tip.
