fuji F810 and batterielife
Started by sharky1961 ·
  1. Hello,
    I have bought a Fuji F810 with Fujihousing for my wife with the Inon z220 strobe. I felt that batterielife of the fuji is extremely short wenn you use the flash. I have the opticalcord from Inon. what are your experiences and how many pics can YOU make with 1 batterie??
    Rob
  2. Hi Rob,
    I have found that if you dial in flash exposure compensation (on the camera) down to -0.7 (the lowest setting), you get considerably more camera battery life. Given that you will be using the strobe on manual anyway (no TTL with this setup), the on-camera flash is only used for triggering anyway, the compensation has no effect on final exposure.
    Hope this helps.
  3. Hallo Rob ,
    I dive with the camera and original housing in cold dutch waters and i get at least 60 images in water that is below 10 degr. C. I also turned down the power of the internal strobe and startup of the camera is also very fast.
    When i dove with the camera in warm wters it lasted easily 2 dives.
    Regards Frank
  4. hello Frank,
    I also dive in cold dutch waters <_< , do you set strobepower to -0.7 and what other settings do you have for the camera?
    doei,
    Rob
  5. Hoi Rob
    In my original answer i forgot ot mention that i use a inon d180s strobe so i use the lowest setting for the internal strobe.
    In regard to other settings i'm still experimenting with all! This is the first underwatercamera for me so a shoot a lot and it is still hit and miss.
    By the way saw a sepia yesterday at the GoesseSas and didn't bring my camera with me ( how stupid can you get !! )
    Dive save Frank
