YS-DX90 and NiMH battereies
Started by scotdiver ·
  1. My 2100MAh rechargables do not fire up the strobe, but normal alkaline AA do fine.
    There is a bit tucked away in the manual that states up to 1000MA but then produces a table for flashes with 1700 MAh.
    Before I invest yet another set of rechargables and charger, does anyone else have practical experience with rechargables that work with these strobes.
    Rob
  2. The manual has not been updated in years, batt's up to 2400mah have been tested and work fine on this strobe. Try bending down the contacts on the battery cap, they flatten out easily.
    For more information see this post: Sea & Sea Battery Press Release
  3. Thanks for the info - I'll have another go this afternoon with the contacts pulled down a bit, though one of the strobes is brand new.
    Rob
    (ex Farmington NH)
  4. Problem was the contacts flattened in the battery compartment lid. Even on the new strobe!
    Many thanks
    Rob
  5. I had that problem with my YS-90's so often I was tempted to but a small dollop of silicone under them to support them.
    OK, I was more than tempted... and it worked pretty well. Until one of them flooded for some "unknown" reason. I was a bit chicken to continue the practice, even though I don't really think the flood was related.
  6. Rob, Glad to help out with the battery contact tip.
    FYI, A smal strip of rubber about 1/8" thick is added under the contact tabs on the YS-120 battery caps to keep them from flattening out. In fact this is the only difference between the YS-120 battery cap and the YS-90's, YS-60 and YS-50. When replacement of the battery cap is necessary we always use the YS-120 type.
