Canon 15MM Fisheye
Started by kriptap2 ·
Canon 15MM Fisheye
  1. Thinking of getting the Canon 15MM Fisheye for my 20D, has anyone used this lense, if so what did you think?
  2. A search on this forum for "15mm fisheye" comes back with many, many topics.
  3. I'm not a Canon user but I use the Nikon 16mm that is very similar. I think that this is a great lens for big animals.
    In the Maldives I used this lens for all my whaleshark and manta ray photography.
    In Cayman, however, I prefer a wider lens for UW wideangle. That is because the main UW subject matter in Cayman is the beautiful UW scenery - and I want to shoot that with as wide a lens as i can.
    I realise that such a lens is not yet available for the Canon's (apart from the 1Ds series). So the 15mm is an excellent choice. But make sure you get a domeport that is compatible with a 180degree fisheye should Sigma or Canon bring one out for their cropped sensor cameras. Having both would be ideal.
    Edited by Alex_Mustard
  4. Hi,
    I choose the Sigma 15mm FE to play with my 20D, the optical quality between Canon and Sigma Fisheyes is the same, the construction is quite good and Sigma is about $150,00 more cheap.
    It will work as 17mm in you 20D without fisheye efects.
    I did picts a lot this week here in Cayman using my Sigma Fisheye in a Aquatica 8" dome port with shade without any problems. I loved the results.
    Regards
