I just got the Ikelite housing for my Canon Digital Rebel. I've got two lenses that I'm somewhat unsure of which port to use, the new 10-22 wide angle (awsome lense!) and my 100mm macro. It looks like they want you to do the flat port at least for the macro. Any body have advice here?
- 4Posts
- 4Replies
Ikelite Port Recommendations
Have you tried the Ikelite website for port data
http://www.ikelite.com/web_pages/2port_canon.html
Hope this helps.
Bill
Thanks for the reply Bill. Yes I've looked at their site, but it looks like I have options between several ports including their 8", so I'm looking for recommendations there.
Corby
Hi Corby,
I recommend the flat port with manual focus knob for the 100mm lens - can't remember the exact number of the port but it's obvious from the chart. This port will let you do full time manual focus over-ride if you want to. Be advised that you can't use most diopters on the lens when using this port.
For the 10-22, you really should get an 8" dome, either from Ikelite or Aquatica.
Sincerely,
James Wiseman
