Choice of lens
Started by Pedda ·
Choice of lens
  1. Hi,
    If you're out on a dive and the only intention was to take pictures of people underwater diving. Which of the following lenses would you prefer if you had a D70 camera?
    10.5 mm FishEye
    15 mm FishEye
    10-20 mm
    12-24 mm
    Any other suggestions?
    Regards
    Peter
    Edited by Pedda
  2. Hi Peter,
    When you get close and shoot a model with a wideangle or fisheye lens, it can make them look very unattractive. Body parts at the edges of the frame can look VEEERRRRRYYYY strange indeed.
    Consider that most topsides photographers prefer a 28-70 AFS or a 50mm 1.8 or an 85mm (on a full frame camera).
    With that said, underwater photography is closeup photography. Rather than setting up for a studio shoot w/ the model 6-8 feet away, we usually try to keep subject distances down to less than 3 feet.
    If you are JUST going to shoot a model as the main subject, I'd recommend the 12-24DX or the 17-55DX, both rectilinear lenses.
    If you're going to shoot the reef w/ the model as secondary interest, I'd use the 10.5 or the 12-24DX.
    Edited by james
  3. Good demonstrations Peter,
    Just one of-topic comment: the vertical thumbnails are present distorted, the gallery software you use 'pulls' them horizontally.
  4. I think all of those lenses have a role. I'd go with Peter that the 16mm is the safest choice.
    Personally, I do most of my model shots with the 10.5mm. But out in the Maldives recently where I had a model with me for 2 weeks I shot her with the 10.5mm, 16mm, 17-35mm (which was really nice for two shots with fish, anemones etc) and even the 60mm.
  5. I did almost nothing but shoot people on film for years, lens of choice was Nik V and 15mm, then i got an 18-35mm for my housed F90 and i loved the fact i had some versatility with the zoom aspect.
    I think the 12-24 would be my choice as you can then work with full body silhouettes with full frame sea fans but also zoom in and get face/upper body shots with only a portion of the sea fan.
  6. I'm with Mike on that one, altough I do my diver shoots usually with a 14mm, the 12-24 has got the sweet range for this kind of images, if the model is really secondary ei: backlit shape in background or only a part of the final image then the fisheye is OK, any close up and you risk ending up with quite a deformed and possibly upset face.
    regards
