Problem with pictures
Started by scubak ·
  1. I am new to digital UW and have a Oly C-5060 in an Ikelite housing with the DS-125 strobe and the last 2 dives I notice a dark black area in the lower left hand corner of the image....
    Is this a "shadow", a strobe position problem, a camera problem?
    Any advice would be appreciated.
    Kirsten
  2. Post a couple of photos for people to see, I'm sure you'll get some help.
  3. post-2595-1119045430_thumb.jpgHello Kirsten and welcome to Wetpixel
    By chance, are you using the Ikelite dome port with your housing ?
    I had a similar problem and it turned out the front shade for the dome wasn't aligned correctly. I had vignetting in the bottom right corner. Realigning the dome shade corrected the problem.
    If you aren't using the dome port, check to make sure your camera is positioned inside the housing with the lens in the center of the port opening.
    Not sure what type of dark corners you are getting, but if it looks like this, it's mechanical vignetting and you should be able to correct it without much of a problem.
    Edited by dmoss
  4. sometimes with these camer4as when you zoom you get the port showing up ... i had this with the L&M housings with dry ports ... with the wide angle ports you sometimes get the reflection of the writing on the end of the lense show up too.
  5. Your port and lens are not totally compatible. You get that same effect when you stack filters on a lens.
    Joe
