Source for Nikon Diopters?
Started by JoelD ·
  1. Hey gang,
    I've recently jumped off the underwater digicam dingy and made a heroic swim to the the dSLR yacht. Ok, so it was my visa card that needed the O2 when I climbed up the ladder...
    As always the fine folks here at Wetpixel had a great deal to do with my new rig. I ended up with a d70s, 15mm sigma, 60mm nikon, and the 18-70 nikon kit lens and I have an order in for the new Ike d70 housing, 8 inch dome, etc, etc.
    According to Ike's site, I'm still going to need a +4 diopter for the 18-70mm to get full range of operation, my problem is that I've had zero luck tracking one of these little fellas down. I've tried B & H, I've tried Adorama, 47th street, Amazon...
    Anyone have a suggestion as to where one can be obtained or a part number?
    /wave Olympus5060 set up, you'll be missed......briefly I belive.
    Joel
    http://www.widgetsandmore.com
  2. From what I understand, the filter size for the lens is 67 mm. B&H sell a Tiffen set with +1, +2 and +4 diopters for $48 or so, a B&W version +4 for $36 or so (these are called close-up lenses). For the best quality you might look at the Canon version (your camera might break though) which comes in a 77 mm version, for this you will need a step down ring as well.
    Bill
  3. I have the same set up you are putting together. I have the B&W +4 (B&H # BWCU467) which works well. It is in stock and $36.
    My 2 cents....
    Chris
  4. Thanks for the input guys!
  5. I would avoid the larger diopter option with the step down ring. I am not sure on the 8 inch dome but if you had a step down ring and the diopter on the normal dome port at the 70mm end it would hit the dome.
