what do I need ?
Started by petr ·
what do I need ?
  1. Hi All,
    I will go with the Ikelite D70 housing, Sigma 15mm, Tokina 12-24, Nikon Micro 60mm, Nikon 18-70mm and the 8" dome port. Which gear I need to order? Any extensions rings, zoom gear or something else?
    Did somebody try to fit the Tokina 12-24 with the 8" dome port?
    Thanks.
    Petr
  2. The Ike housing comes with a zoom and clamp set to the 18-70 lens.
    For the Tokina you need to check what port sleeve you need to operate the zoom, if it’s the same as the Nikon 12-24 you can use the #5509.12 internal port sleeve with rubber pads.
    You also need a close-up diopter +4 for the 18-70 to get full range focus behind a dome port.
    Edited by Arnon_Ayal
