Ikelite CP 8400 housing review.
Started by davephdv ·
  • 15Posts
  • 15Replies
  1. I thought I would try to write a little review of the Ikelite housing for the Nikon CP 8400.
    First the camera. This camera is an 8 mp camera with a lens that is the equivalent of a film slr lens of 24 to 85 mm. An optional Nikon wide angle lens increases this range to the equivalent of a 18 mm lens. This lens is I believe the widest zoom lens on a digicam available today. The camera has a macro mode that enables you to focus down to about 2 cm. Both of these attributes are very significant for UW photography.
    For those of you who cut your digital teeth on the Cp 5000; this camera is in most respects a much superior camera. At ISO 50 it gives a cleaner image than the 5000 with much better color reproduction. I have on several occasions had people like images taken with this camera as superior to the same shot taken with several of the current consumer level dSLRs. I don't claim the image is as good as a consumer level dSLR but it is hard to tell them apart at times. Image wise.
    The shutter lag is much improved. When you have good light it is very fast. As others have noted the LCD momentarily freezes up when you autofocus on macro subjects in poor light. More on this when I discuss the Ikelite housing. This is the first digicam I have shot in which the shutter lag problem is manageable. Though not on the level of a dSLR the shutter lag is a minor problem. Not a deal breaker like on other digicams. I have read many suggestions on how to work with shutter lag. I never thought any of them worked very well until I started using the 8400.
    The camera writes slowly to it's CF card. I always shoot Jpeg fine.
    The battery is much improve over that of the cp5000. It will last 2 and 1/2 long dives. I have always have had it last two full dives. Even when I shot 402 images in 3 dives during the Monterey beach photo contest.
    This is the first camera I have used with an EVF. Though others seem to dislike them I like this one. I use it when I am in a bright environment. It seems to work fine.
    The Ikelite housing follows the model used with the CP5000 and similar cameras. It is compact. and very strongly made. The controls seem very easy to use and access to them is very good. It seems much easier to use this housing and camera than it was with the cp5000 and it's Ike housing. Not sure if Ike has improved it's housing or the camera controls have been improved making it easier to access them through the housing. Probably some of each.
    As far as I can tell all the controls are accessible. The one control that really stands out is the lever for the autofocus/autofocus lock/exposure lock. This is controlled by a lever that is parallel to the shutter release lever. You can access both of these levers with the fingers of your right hand. This becomes vital to shooting of this camera UW. As noted above when focusing on a subject (macro) in poor lighting the LCD freezes up for a fraction of a second. You can use this lever to focus on a macro subject. It will autofocus the camera on the subject. The LCD freeze then occurs and then the LCD resumes live display. You can now fire the camera and strobe with NO shutterlag. While still holding the lever you can slightly reposition your shot and fire again for as many shots as you want to take. If you subject doesn't move too much you can use this method to virtually eliminate the shutter lag problems for macro and close up subjects.
    I don't find the shutter lag to be a problem for wide angle subjects with decent lighting. The camera shoots very fast. However you can use the above method to set your approximate focusing distance very quickly and then rely on depth of field to keep you subject in focus.
    The Nikon wide angle add on lens; like the similar one for the cp5000 is very sharp and fairly inexpensive (~250$). When combined with the Ikelite optional wide angle dome port it gives you a wide field of view and a very sharp image.
    The one area where this camera lacks in comparison to the CP5000 is in it's macro mode. As previously mentioned it can focus down to under 2 cm. You can focus almost on the front of the housings flat port. The problem is that the camera will only function in it's macro mode for the widest 1/3 of it's focal range. This means that even though it will focus extremely close you cannot get a very small subject to fill the frame. Meaning no 1 to 1 macro. I would estimate the about 1:2 macro is about the max. When getting to these very small subject you will be very close to the housings port surface. This makes it hard to get good lighting as the subject is so close to the camera and housing. The size of a subject you can shoot is even more limited when you put the camera in macro mode when the wide angle lens is attached. This is because of the very wide angle of coverage of this lens. You can focus on the front of the dome. But once again you can only focus on the widest 1/3 of the camera's focal length.
    I have found it best to use two manual slave controllers for lighting. One of them set in slave mode and the second attached to the housing by a synch cord. The ike web site says you cannot use the housing with a slave only strobe. I however rigged one up using Ike's dttL slave sensor and was able to shoot it no problem. In any case you have to elevate the camera's on camera strobe in order to file an external strobe. Even though you turn off the internal strobe in the camera's menu system.
    I am still experimenting with the best way to rig up the strobes. The camera works best with the two handle tray that comes standard. However for Kayak diving, rough conditions, beach dives, and free diving I really like using a one handle only tray. I have rigged up several nikons trays to use in this mode but they are all very inferior to using Ike's one handle tray.
    The Ike extended mount handle is excellent. It is the easiest way to mount the manual strobe controller to the housing. But it does get your strobe far away from your subject when you are shooting those problematic very close macro subjects. I have used the much shorter but similar UL handle mount. It doesn't allow you to mount the manual strobe controller. With it I use with Ikes clamp with stud mounting. This is a very good clamp and you can mount either of Ike's strobe controllers or some external lights. I also use the the saddle clamp made TLC. It attaches anywhere on the TLC square arms and allows any ball joint to attach to it's other side. I have a light saddle and both TLC and UL ball joint saddles. These attach to the manual and slave strobe controllers. I find I change the mounting method depending upon what type of subject I anticipate shooting. I would start with the Ike extended mount handle and stud clamp if I was limited in what equipment I had access to.
    I prefer the dttl slave sensor when I shoot wide angle shots.
    I recently sold my D100 dSLR housing. I have been shooting this CP8400 rig for several months and in general have been surprised that I haven't missed my D100 more. I have had some frustration with shooting small macro subject as discussed above. The dSLR is clearly superior for that kind of shot. But otherwise the CP8400 and housing hold up very good in comparison. This at a much lighter rig to transport and and much less expensive package to purchase.
    Here is the housing with the optional wide angle dome port and lens. Note the Ike extended handle mount with a manual ttL controller.
    Images taken with this rig are at:
    http://homepage.mac.com/daveburroughs/PhotoAlbum29.html
    Edited by davephdv
  2. This side view of the housing shows the levers for the shutter release and the autofocus lock. Note how you can easily manipulate both with one hand.
  3. Cool Dave - thanks for posting.
  4. Excellent review and really nice shots Dave.
    Yeah, *SUCH* a pity, they disabled macro mode, in the tele end of the zoom.
    Getting close though!
  5. Dave, how do you have ur ds125 setup (positioning) for macro?
  6. I have both set up with manual controllers; one on slave. I use my usual mish mash of Ike, TLC and UCLS arm components. I very the position constantly so I can't give you a preferred strobe position.
    I hook up the hard wired manual controller using the Ike extended arm. The slave I position next to the other strobe using Ike's stud clamp. I very the means for attaching the very necessary ( for macro) focusing light. I usually attach it to a strobe arm using the TLC saddle clamp. Sometimes I use a triple clamp instead.
    The biggest problem that I have is that to get small marco you have to get very close to your subject. To get the lighting in there is tricky and why I am always changing depending upon the conditions.
  7. Thanks Dave, I have much to learn.
  8. Believe me; everyone has a lot to learn. Just keep shooting and critically analyzing your photos. Best way to learn and you don''t have to pay for the film and developing.
  9. Dave,
    That was an excellent write up, good stuff. I completely share your frustration with the macro functionality, if it would zoom in the full range instead of just 1/3 it would be pretty close to perfect in my view. I've been using the Inon 165 macro lens on the front of the Ike housing and it works really well - allows you to at least shoot 1:1 macro however positioning the strobes is a pain.
    The only other major gripe I have found with the CP8400 is that it generates considerable noise, even when shooting at ISO 50 or 100. It is defiently noticeable when you enlarge the image to the full size. The noise and macro mode are the two issues that bug me, why couldn't Nikon use the same macro features as the CP500!!!
    And finally, I run dual DS125's with the 8400. The primary is connected via a sync cord with a manual controller and the 2nd strobe is triggered by the Ike TTL sensor. On a recent trip to Vietnam my sync cord died (loose wire connection at housing plug). Fortunately I found that the internal strobes BOTH slaved off the internal camera flash using the Ike difuser on the front (glad I remembered to put that in the bag!). So it is defiently possible to get results slaving the strobes off the CP8400 internal flash.
    cheers,
    Dave
  10. I always shoot the camera at ISO 50. I thought the camera had very clean images at that ISO. Appreciably better images than the 5000. Maybe I'm' not critical enough of my images.
    I have the dTTL slave sensor. I like using it with wide angle. I have found that with the critical placement of strobes for macro with the 8400 that it is better to use a second manual controller in slave mode.
    When I first got the housing I tested is using the camera's internal flash to power an external flash with a slave sensor. As you noted it worked fine.
    Nice Vietnam gallery (and the others). How did you find the quality of the diving there compared with the rest of IndoPacific diving?
  11. Nice Vietnam gallery (and the others). How did you find the quality of the diving there compared with the rest of IndoPacific diving?
    The diving in Vietnam was sensational. Much better than what I expected. It was defiently some of the best macro/critter diving that I have done and I found it more productive than PNG and the GBR in regards to unusual critters and species diversity. There is excellent diving out of Nha Trang including pinnacles that drop down to 45 metres that are covered in fans and corals, I didn't bother trying to take wide angle as there was too much small stuff to be found. I found a total of 66 different nudibranch species including 5 that are new discoveries! The big fish life is disappointing as the place has been HEAVILY fished however there are plenty of the small coral reef fish species. Visibility varied from 5 to 20 metres and temperature was about 28 degrees.
    Vietnam is also very cheap, easily the cheapest country that I have visited! The accomodation and food is excellent, it is easy to get around and Rainbow Divers run a very professional organisation and catered well for my KISS rebreather. The Rainbow Divers website is www.divevietnam.com
    It was so good I'm organising a marine critter/nudibranch hunting expedition back there early next year!
    cheers,
    Dave
  12. im interested in that vietnam trip!
  13. I just sent my 8400 for Nikon to fix. I was practicing some macro shots when the lens got STUCK. I just hope it comes back before my Labor Day Dive trip to Miami.
  14. im interested in that vietnam trip!
    Just been diving with Rainbow Divers in Nha trang (Viet Nam), they are very professional and the price is pretty good for 2 dives ($60 pp) That includes all equipment, all fees and refreshments.
    We did 1 dive at Debby Beach and 1 at Moray Beach. We have no photos from the dives as our camera doesn't have a housing, but we took some whilst snorkeling in between. There not going to win any awards. We saw Moray eels, Puffer fish, Barracudas, Cuttlefish Parrot fish, Angel fish, Wrasse and some of the other usual suspects. It took less than an hour to reach the dive site from the centre.
    http://timburnett.blogspot.com/2010/01/scu...ng-vietnam.html
