Nexus D70 and D70s
Started by nat ·
Nexus D70 and D70s
  1. I got Nexus D70 and need to buy D70s as my back is it fit in my old housing.?
  2. The Nikon D70 and D70s are physically identical in dimension, aside from a very small increase in LCD screen in the back all buttons and dial are at the same place. The difference is in the internal digestive system of the camera mostly.
    regards
  3. There is really no difference between the two cameras except slightly bigger LCD, cable release on d70s, longer lasting battery by a little bit. The new firmware upgrade for the D70 essentially makes it identical as far as autofocus, speed, etc.. Consider saving yourself a few bucks and get a d70 until newer model comes out.
    Other manufacturers have not had to alter housings to get the d70s to work in the same d70 housing. My guess is it will fit. YMMV
    Tony
    Edited by critter
