DS-125 Strobe Arms
Started by dawktah ·
DS-125 Strobe Arms
  1. Hello!
    I was looking at Ikelite website and noticed that they have more options in the 1.25" ball size and also quick release handles. Will I find the need to upgrade the arms or will the 4086.61 kit be sufficient. I have a 100mm macro I want to use after I become more proficient with rig.
    Also I'm not following which components I would purchase to use the Quick Release handle with ball. What would I need to attach it to Ikelite Rebel Housing?
    Any pictures of this set up?
    Thanks!
  2. Do you have the strobe/arms yet?
    I find the ikelite arms are not as good as ultralight with the weight of the DS-125. Also the clamps are much harder to adjust underwater, though that may be because I'm having to do them soooo tight with the weight of the strobe.
    cheers
    Lndr
    Edited by Lndr
  3. I have the strobe kit, came with 4086.61. Housing was neutral in salt water will be interesting to see how rig behaves with strobe on it. Slated to make rig 5 oz. negative.
    What I don't understand is which parts from strobe to my housing do I need to use the quick release handles.
    Edited by dawktah
  4. Bottom section of #4086.61 is the #9571.3 component that drops into the Release Handle after removing the little vinyl cap on top of the handle tube.
