I would like to buy the olympus c-770 and the housing PT-022.
Can I use the built-in (pop-up) flash of the camera when it is
in the housing?
If you have experience, are you satisfied with the c-770 and/or PT-022?
thanks! Peter
Hi,
Yes the pop up flash works in that housing. I use the C770 predecessor the C750 with a PT018 and good-ish results are obtainable but it is very restricted at the (not very) wide angle end. An external strobe helps a lot.
I would think very carefully about a C5060 or a C7070 first, I do regret not going down this route originally. The Fuji F810 is also very highly thought of on this forum but I have no experience of this.
