F/S - Seacam F100 Housing / Nexus Adapter Ring
Started by Fishooter ·
  1. Seacam F100 housing for sale, 60 mm macro focus gear all in mint condition. No other Seacam accesssories available. (See the attached jpgs - more jpgs available.)
    Housing has never been flooded, twin Nik. synchs., audible/visible leak detector, spare O-rings and housing guide pins, Seacam O-ring grease and Seacam Silver body cleaner. Black flocking material inside is flawless. Interior appears brand new. Little to no signs of wear on the outside. $1700.00 + actual shp/ins.
    I also have an Adapter Ring which was made by the team at Sub Aquatic camera. Ring fits the Seacam and allows you to use Nexus ports with the Seacam. This was made for a project and not completed in time so I have not yet tested it with the housing. Housing has been sucessfully presssure tested with the adapter ring.
    Adapter Ring $275.00 + actual shp/ins.
    Buy them together - $1850.00 + actual shp/ins.
    Contact me if interested.
    Paul
    Edited by Fishooter
