D70 Battery Question
Started by jcclink ·
  1. Anyone had experience shooting the D70 in 30-35 deg temperatures? About how many shots on a fully charged battery under these conditions?
  2. Don't know about the D70 yet, but I have shot the D100 topsides a lot in temperatures around -20 to -25 Centigrade which is, ermm, let's see now, about -5 to -10 Fahrenheit. In these temperatures a fully charged battery lasted for about 100-150 images or thereabouts. The images being mostly landscapish stuff, so mostly manual focus, no flash.
    timo
  3. I have used my Ike Housed D70 on several ice dives. These dives are generally in your temp range. Very cold on the surface and chilly under the ice. I can't tell you exactly how long it will last, but I have never had to change the battery while doing several ice dives in one day. I would say at least a few hundred shots. Hope that helps.
  4. Hi,
    When I use the camera underwater (28 degree Celsius) I can easily make 150 pictures a day for at least 2 days. (No use of internal flash) Then I did recharge it, cause I don't like the experiance under water without bat-power during my holiday. :)
    Above Water in 30 degree celsuis environment I made maybe 200 to 300 pictures with one battery fill splitted up through several days.
    In other words the battery is excellent and it last long enough. As I usually use an external flash (above and underwater) the battery of the camera has never been a problem to me. If you have access to power during the night just charge it for the next day. I did think about buying a 2nd spare battery just in case and it might be recommended.
    Best regards,
    Chris
