Change bulb in Epoque strobe
Started by mkgraphics ·
  1. Hi, All
    My first post to this excellent site, looking forward to getting alot of useful info from you guys and putting in my 2 cents if I can help.
    I have a Epoque strobe ES-150DS, the light does not show charged and will not flash. Was not flooded or dropped, is the bulb bad? If so can it be changed?
    Any help will be appreciated.
    thanks
    mkgraphics
  2. Electronic flash units (strobes) do not contain filament based bulbs and do not "burn out". They use Tubes which contain a xenon gas which glows when exited with a high (about 300) voltage. These tubes rarely if ever need replacement unless physically damaged. Most likely your problem is in the power connections or an oscillation circuit component.
    Interestingly over the years of repairing photographic equipment I've noted a direct correlation between the finding of impact, sand or liquid damage and the owner's claim that it never happened. ;)
    Edited by UWPhotoTech
