D70 (Ike housing) + SB800 (Subal housing)
Started by mmb ·
  1. Thats the question. I've one D70 and the Ikelite housin (the old one without ittl) I'll have a SB800 nikon flash. If I update the housing to the iTTL and buy the Subal housing for the flash....
    Will it work in iTTL with the 4115.31 sync cord for nikonos strobes?
    Did the 4115.31 sync cord for nikonos strobes have the five pins fixed and conected?
    Did the updated housing working with this strobe housing?
    Thanks to all!!!
  2. NO. It will not work. If you update your housing, you can have ittl with ikelite strobes only.
    Or you can replace the bulkhead with the one subal uses for use with the flash housing and you can have ittl with the nikon flash.
