Thanks to Stephen Frinks I got my D70 housing.....
Started by MPC ·
  1. was down in the Keys for Labor Day weekend and rented a 15mm Nikonos lense from Stephen Frinks Photo store and low and behold they have an Ikelite housing for a D70 that a guy used for a week long class and decided to up grade. It came with a 6" dome, 105 port, double arm tray, 2 arms, sync cord, gears for zooming, slave sensor. Special thanks to Liz who even threw in a Pelican case so I could bring it home :unsure::P:( The dome is good for my 18-70mm, and Stephen said I could use a 60macro too. I could not pass up the deal.
    Now I am in the market for stobes, Liz recommended DS-125's , probably would start with one, is that the way I should go? Or is there another choice???
    Thanks for any info.
  2. Congrats on your new rig :unsure::P
    the DS-125's would be a good choice.....if you upgrade the housing to iTTL, the DS-125's or DS-50's are the only strobes that will work in iTTL
    FWIW, I would get the flat port for the 60mm
    Karl
