Powershot S30 Strobe
Started by Uranium ·
  1. hi! I've been using the Canon Powershot S30 underwater for some time now believe that i would require a strobe for better pictures. Unlike the nikon cameras, this one has no connection for the strobe. So, is it possible for a strobe to be used with this camera?
    Wesley ;)
  2. Yes! I believe that you can use the Ikelite DS50 or DS125 or the Sea and Sea YS90 DX.
    For more information try using the search button and enter "slave strobe" or YS90DX
    hope that helps,
  3. Thanks! However, I would like to know how does this actually work? I've read your article on strobes for the camera but don't really understand it. I'm sorry. So does the camera flash its own flash and the strobe will pick it up and flash? Then, how does the synchronistion occur? (There is no connection). Thanks!
    Wesley
  4. Hi,
    A slave strobe works 'cause it has a slave sensor. The slave sensor "sees" the light from another flash (your camera's flash) and tells the slave strobe to fire.
    There is no connection really.
    To make sure that the slave strobe "sees" the flash from the camera, people have devised flash deflectors, or fiber optic cables to "shoot" the light from the cameras flash to the slave sensor.
    I hope that helps,
  5. I think i've got it. So the slave strobe and the camera's main strobe will fire at the same time? Don't you need to cover the camera's flash to avoid backscatter?
    Also, I'm thinking of purchasing a strobe for my nikon coolpix 4500. What would you recommend? Something that gives me the most "bang for the buck". Thanks alot! By the way, I don't think the coolpix has the preflash system. So is the nikon coolpix compatible with the slave strobe? Or can it only be used with the hard-wired strobe?
    Wesley
  6. There are very few strobes that are JUST slaves (but there are some). Most strobes allow you to attach a sync cord but also have a slave sensor.
    You can use just about any strobe for your Coolpix so just pick something that fits your price range. I would ask Ikelite for more detailed information about the 4500 - I have only used the 990, 995, and 5000.
  7. Just be sure you are using a strobe that is suitable to a digital camera and can ignore the pre flash.
